Jackrobbo
Oct 08, 2024Aspirant
Nighthawk M6 5G router drops connection every night around midnight
Hi All, Basically the problem as described above, really struggling feel like I've tried everything. So strange that every night on the dot it conks out - says it has connection but there’s nothing...
rcpax
Oct 18, 2024Luminary
Can you tell us what network you're using? are you using an ATT sim? The temps can be seen in the diagnostics page. It runs warm, but if you run it without the battery, it should be okay.
Jackrobbo
Oct 22, 2024Aspirant
Using Vodafone here in the UK
- rcpaxOct 22, 2024Luminary
it could be a network issue. ATT is known to "hang" the connection after being connected for a while. You might not have to restart it. Try toggling airplane mode, if it starts getting data after toggling it, it must be a network (carrier) issue. The only other time the hotspot would drop the connection is when it's overheating.
