stephenlatty
Mar 24, 2023Follower
Nighthawk M6 5G WiFi 6 Mobile Router Turn Specific Channels On/Off
Is it possible to turn specific channels off across the 5G band on this device? Or am I limited to turning the 5G or 2.4G on or off as a whole?
Mar 25, 2023Guru - Experienced User
If you use the netgear mobile app you can go in through wifi settings and change the channels.
Just tested it to ensure on my MR6110
NETGEAR Mobile App | NETGEAR Support
JohnPeng
Mar 25, 2023NETGEAR Expert
Yes. You can manually set which WiFi channel to use on 5G or 2.4G. But you can only set the device to use one certain channel.
Thanks
John
