TBone1985
Jan 09, 2023Aspirant
Nighthawk M6 and Dell WD19 Dock
I have a new Nighthawk M6 Pro from AT&T. When connecting directly to the ethernet port from my laptop, everything works fine. However, when I connect to it from my Dell WD19 docking station, the co...
JohnPeng
Jan 10, 2023NETGEAR Expert
TBone1985 wrote:
Yeah, moving the M6 to my laptop will cause WiFi signal in other areas to drop. For now, I'll connect to my laptop directly, but a solution would be great.
Try connecting M6 to your docking's USB port, not the laptop's USB port. Let me know whether that works for you.
TBone1985
Jan 21, 2023Aspirant
I ended up buying Netgear mesh network router and it’s connected to it. I can then connect it to the network connection in the router. Working well.
