bassue's avatar
bassue
Follower
Jun 18, 2023
Nighthawk M6 Compatibility (Unlocked)
So I want to get a nighthawk M6 hotspot but I’m worried it won’t be compatible with my carrier (Mint mobile). It says AT&T and T-Mobile certificate so I just want to be sure it’s of its compatibility before I cough up a big chunk of change.
Any info is helpful, thanks!
1 Reply
  • Might want to be more specific as to which variant of the M6 you're looking at.  Is it an MR6150, MR6550, MR6500 or MR6400?  Compatibility depends on which version of the M6 it is.  Case in point, an MR6500 AT&T version will not allow all of the T-Mobile frequency bands to be used, even if unlocked.
