youngb989
Mar 16, 2023Aspirant
Nighthawk M6 Mobile Device
I paid $700 for this hot spot so I can connect to the internet. Every 10 minutes it disconnects and then tells me I have to go to Advanced, Settings, Cellular, blah blah blah. Why does this keep do...
JohnPeng
Mar 17, 2023NETGEAR Expert
Please capture a model.json file and send PM to me for review.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
John
youngb989
Mar 17, 2023Aspirant
This is what it keeps doing every 10 to 15 minutes. It kicks me out constantly.
- JohnPengMar 17, 2023NETGEAR Expert
Looks like you are using MR6150-100NAS. Could you please advise which carrier you are using and what is the plan on the SIM?
This is looks like a SIM subscription issue.
Thanks
John
- youngb989Mar 17, 2023Aspirant
Carrier is AT & T. They gave me a brand new sim which we put in at the store. My hot spot keeps telling me sim card is full and I need to delete things off it. I have no clue what that means. As for plan, they gave me a phone plan with unlimited everything because their data was only 25 MB a month I believe. The girl told me with everything I am putting on the hot spot (laptop, tv, playstation), it would be less money to get a phone line than a data only sim.
I truly appreciate your help, this is driving me nuts here.
Could you please check what is the APN setting on your device by tapping Settings -> Mobile-> APN?
If it is set as broadband, you can try set to nrbroadband or vice versa to see whether it helps.
Thanks
John
