youngb989
Mar 16, 2023Aspirant
Nighthawk M6 Mobile Device
I paid $700 for this hot spot so I can connect to the internet. Every 10 minutes it disconnects and then tells me I have to go to Advanced, Settings, Cellular, blah blah blah. Why does this keep do...
youngb989
Mar 17, 2023Aspirant
This is what it keeps doing every 10 to 15 minutes. It kicks me out constantly.
JohnPeng
Mar 17, 2023NETGEAR Expert
Looks like you are using MR6150-100NAS. Could you please advise which carrier you are using and what is the plan on the SIM?
This is looks like a SIM subscription issue.
Thanks
John
- youngb989Mar 17, 2023Aspirant
Carrier is AT & T. They gave me a brand new sim which we put in at the store. My hot spot keeps telling me sim card is full and I need to delete things off it. I have no clue what that means. As for plan, they gave me a phone plan with unlimited everything because their data was only 25 MB a month I believe. The girl told me with everything I am putting on the hot spot (laptop, tv, playstation), it would be less money to get a phone line than a data only sim.
I truly appreciate your help, this is driving me nuts here.
- JohnPengMar 17, 2023NETGEAR Expert
Could you please check what is the APN setting on your device by tapping Settings -> Mobile-> APN?
If it is set as broadband, you can try set to nrbroadband or vice versa to see whether it helps.
Thanks
John
It just tells me all below on device.
APN: ATT Broadband
PDP: IPV4V6
PDP Roaming: IPV4
