ADOOL
Aug 05, 2023Tutor
Nighthawk M6 mr6110-1s4mes Doesn`t work on 5G N78 frequency on STC Saudi Arabia
Hello, I have a Nighthawk M6 device, model mr6110-1s4mes, version NTGX65_12.01.16.00, but unfortunately it does not work with 5G on STC n78. I hope to find a solution to this problem, noting that I n...
- Aug 05, 2023
We are in the process to release the MR to address the issue. Expected to be released in the next couple of weeks.
Please standby.
Thanks
JohnPeng
Aug 05, 2023NETGEAR Expert
Please standby.
Thanks
ADOOL
Aug 06, 2023Tutor
Alright, I'll wait for that, thank you
- mcuadradoAug 10, 2023Guide
Can you contact me privately , i will try to help with the new release .
Regards!
- BRKAN505Aug 30, 2023Aspirant
i have the same echo , for the same model .
can you send me the update
- Ahmed_alharbiSep 11, 2023Aspirant
I faced same issue.
- mcuadradoSep 11, 2023Guide
Hello, new firmware is now releasing in different waves , I estimate it will be available during this week for all the devices
