Ahmed_alharbi's avatar
Sep 11, 2023
Nighthawk M6 mr6110-1s4mes Doesn`t work on 5G N78 frequency on STC Saudi Arabia‏
Hello, I have a Nighthawk M6 device, model mr6110-1s4mes, version NTGX65_12.01.16.00, but unfortunately it does not work with 5G on STC n78. I hope to find a solution to this problem, noting that I noticed that the problem is only with this company. I have another company that uses the n78 frequency and Frequency works on the device
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Ahmed_alharbi
    Please be informed that a new firmware will be available in the next 24-48 hours and be pushed to all MR6110-1S4MES (STC) units in the field.
    FW: 12.01.31.00
    PRI: 02.03
    Blanca
    Community Team
