ADOOL's avatar
ADOOL
Tutor
Aug 09, 2023
Nighthawk M6 mr6110-1s4mes (Use the supplied power adapter when operating without battery)
My problem is when I try to operate the device only via the cable without using the battery, I receive a message in the device stating (Use the supplied power adapter when operating without battery) ...
  • ADOOL's avatar
    Aug 10, 2023
    Hello, the problem has been solved by doing a factory reset of the device. The problem also occurred to me after an update to fix some problems, as it helped me to provide the device with the new update ( JohnPeng ) because I was having a problem with the 5g connection of STC Saudi Arabia. As for the version of the device, it is from By STC Kuwait
    Thank you for trying to help me ðŸŒ¹
