ADOOL
Aug 09, 2023Tutor
Nighthawk M6 mr6110-1s4mes (Use the supplied power adapter when operating without battery)
My problem is when I try to operate the device only via the cable without using the battery, I receive a message in the device stating (Use the supplied power adapter when operating without battery) ...
- Aug 10, 2023
Hello, the problem has been solved by doing a factory reset of the device. The problem also occurred to me after an update to fix some problems, as it helped me to provide the device with the new update ( JohnPeng ) because I was having a problem with the 5g connection of STC Saudi Arabia. As for the version of the device, it is from By STC Kuwait
Thank you for trying to help me 🌹
mcuadrado
Aug 10, 2023Guide
Can you provide details of your firmware on MR6110-1S4MES ?
it should work in Non Battery operation with the supplied Power supply
schumaku
Aug 10, 2023Guru - Experienced User
"Should" makes a lot of sense. Hope you don't refer to the AC-only config in the menu? Are these general available models, or are we facing some Kuwait stc carrier (locked) devices?
- mcuadradoAug 11, 2023Guide
Not sure how some customers gets the device unlocked, but once the device detects the PA is a QuickCharge, it will oper in non battery mode, of course you need to remove the battery first. I will upload some videos too, Im using also some car lighters compatible with QC that works perfectly in NBO .
