bremagroup
Aug 14, 2022Aspirant
Nighthawk M6 MR6500 VOIP SIP ALG Dynamic DNS
VOIP does not work using the Nighthawk M6 MR6500 over Telstra 4G. 1st issue is with SIP ALG. I called my VOIP provider, they said I needed to disable SIP ALG. How do I do this? There is not a s...
michaelkenward
Aug 15, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- bremagroupAug 17, 2022Aspirant
The User Manual in the download section for my device does not have any information about my two queries:
- How to disable SIP ALG
- How to configure Dynamic DNS
It would appear that the device does not have this capability.
Instead, it would seem that the best solution would be to use a VPN to get my VOIP phone working over 4G LTE.
