Rjl123's avatar
Rjl123
Follower
Mar 27, 2024
Nighthawk M6 Parental Controls
Hi,
I just purchased the nighthawk m6, and have set it up. There appears to be some sort of parental control, and I cannot access many websites.
I have downloaded the net gear mobile app and parental controls are switched off. I cannot find any other settings to change, nor on the router itself.
Any tips? It’s even blocking some work websites.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What tells you that? What happens?
    Tried different browsers?
    Access sites with what? Mobile phones? Desktop PCs? Something else?
