Kringle
Jul 03, 2022Tutor
Nighthawk M6 Pro - Drops Internet After 1-2 hours
I just setup a new M6 Pro on AT&T with 5G. I have full bars and very fast service so it’s not signal or carrier issues. I’ve done line refreshes and run AT&T’s tests and all come back saying everyth...
JohnPeng
Dec 13, 2022NETGEAR Expert
Cohenhouse wrote:
I am experiencing the EXACT same issue with the EXACT same device. Was there ever any resolution to this?
Device reads that it is connected with 3 bars of 5g, but every device says cannot connect to the internet, or have a download speed of .5mb. I restart the device and I'm back to 20mb download for a few hours. Then suddenly back to .5mb. I have to restart it 5 times a day.
If you are AT&T customer with AT&T branded device, please upgrade to the latest release and let me know if you still see the issue.
Thanks
Cohenhouse
Dec 13, 2022Tutor
I am an ATT Business customer and yes ATT branded device, all purchased through ATT directly. I have tried to perform a update and it states there is no update available.
- JohnPengDec 13, 2022NETGEAR Expert
The latest update posted by AT&T is
FW: 10.04.22.00;
PRI 01.20
It may take a while for the update to reach all devices if yours has been updated.
Thanks
- CohenhouseDec 13, 2022Tutor
Thank you for your help. The devices that are either dropping connection or running very slow are not ATT devices. My phone is Verizon. There is a TV that sometimes says "no connection" when there are three bars. Speed test on my laptop during these times says 0.3 - 0.8 mb down, and 8mb up So I know there is a connection because of the up. I reset the device and voila I'm back to 20mb down. So the question is what would that have to do with other devices? I experience it across multiple devices at once that are all updated.
- sjbenderJan 02, 2023Guide
My device was working flawless on the ATT Firstnet network, however at 4G based on the service available at the location. After the firmware update, I now have the same issues as above. When it is working the speeds are faster and then just stop working after a few hours. Reboot the device and it works again for a few hours and stops.
Another issue, if I reboot the device through the web app or webpage, it just turns off. It will not turn back on after a software reboot.
NTGX65_10.04.22.00
- JohnPengJan 04, 2023NETGEAR Expert
NTGX65_10.04.22.00
Please provide the model.json file to me by PM. We will investigate the reboot issue with WebUI.
Thanks
