Kringle
Jul 03, 2022Tutor
Nighthawk M6 Pro - Drops Internet After 1-2 hours
I just setup a new M6 Pro on AT&T with 5G. I have full bars and very fast service so it’s not signal or carrier issues. I’ve done line refreshes and run AT&T’s tests and all come back saying everyth...
Jbees
Oct 25, 2024Aspirant
I have the same issue
Nighthawk M6 Pro not fit for purpose
Diskman
Oct 26, 2024Tutor
The NightHawk M6 Pro Is a very powerful and great Hotspot, but it does need to have the correct Sim Card and firmware update. Almost all come with older firmware and if you can not get it updated then the unit can be difficult to use. Not sure where you live but I would be willing help if possible.
- JbeesOct 26, 2024AspirantThank you for your time
- MooneypaulOct 27, 2024TutorI have an ATT unit and they do not push updates as Netgear does. Netgear will not give me updates to load.
- JBishOct 27, 2024Aspirant
Even if you have an ATT unit.... If not an ATT customer you will not get firmware updates
