Kringle
Jul 03, 2022Tutor
Nighthawk M6 Pro - Drops Internet After 1-2 hours
I just setup a new M6 Pro on AT&T with 5G. I have full bars and very fast service so it’s not signal or carrier issues. I’ve done line refreshes and run AT&T’s tests and all come back saying everyth...
Diskman
Oct 26, 2024Tutor
The NightHawk M6 Pro Is a very powerful and great Hotspot, but it does need to have the correct Sim Card and firmware update. Almost all come with older firmware and if you can not get it updated then the unit can be difficult to use. Not sure where you live but I would be willing help if possible.
Jbees
Oct 26, 2024Aspirant
Thank you for your time
