Sefcik78
Jun 29, 2024Follower
Nighthawk M6 pro & verizon
Recently purchased the M6 pro with Verizon sim. A 60gb plan. It’s literally a brick. Home Screen says it connected to 4g 4 bars but barely loads internet for browsing on our devices. Maybe we get p...
Jun 29, 2024Guru - Experienced User
Have you checked with verizon?
PMcV
Aug 25, 2024Tutor
I had the same problem and tried the solution described in this community forum: https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/NOTICE-Nighthawk-M6-and-M6-Pro-Fully-Certified-with-Verizon-Here/m-p/2362540/highlight/true#M26258 The response from Verizon is that my device is already activated. The device STILL has the problem of not connecting to the Verizon network. ChristineT
- Blanca_OAug 26, 2024NETGEAR Employee Retired
Hi PMcV,
May we please know the device SKU (e.g. MR6150-100NAS)? This can be checked on the box of the product or on the barcode label.
Kindly confirm with Verizon if you are using the correct data plan and the APN settings. You may also check this link: Mobile Hotspot APN Lookup
Blanca
Community Team- DGJBSep 20, 2026Aspirant
I have the same issue this year, even after upgrading my plan to the Pro plan for my Nighthawk M6 Pro
