masterbeat
Nov 15, 2022Star
Nighthawk M6 Pro Constantly Locking Up, Screen Freezing, Dropping Internet
I have a new M6 just 2 days old, will be running fine, and then at various times (no rhyme or reason), can be up for hours, or 5 minutes, the screen looks up, won't respond, drops internet completely...
NWFoto
Dec 09, 2022Aspirant
Mine does the exact same. Have you found a solution?
- masterbeatDec 09, 2022Star
Yes, John Peng at Netgear pushed a beta firmware update to me that solved everything. It's my understanding that firmware is now available to everyone, have you checked for a firmware update?
- NWFotoDec 09, 2022AspirantI updated to the new firmware this morning after sending my reply. But now the thing won’t connect to att.
- JohnPengDec 14, 2022NETGEAR Expert
NWFoto wrote:
I updated to the new firmware this morning after sending my reply. But now the thing won’t connect to att.Can you capture a model.json file and send PM to me?
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
