masterbeat
Nov 15, 2022Star
Nighthawk M6 Pro Constantly Locking Up, Screen Freezing, Dropping Internet
I have a new M6 just 2 days old, will be running fine, and then at various times (no rhyme or reason), can be up for hours, or 5 minutes, the screen looks up, won't respond, drops internet completely...
Mcfarl34
May 29, 2023Tutor
Hi John,
I purchased the Nighthawk M6 Pro last week (Late May 2023) and have the same issues. The firmware version is much newer than the one you discussed in the other string. Is there a fix for this? When it does work it works very well.
igorjrr
May 29, 2023Apprentice
Make sure you return it asap.
You'll see in this and other threads that customers have lost hundreds of dollars believing Netgear would fix the buggy software. It's not happening and you'll end up with an expensive device that does not work.
Return as defective to the point of purchase.
