flayinzerFollowerMar 09, 2023nighthawk m6 pro external antennaIf I connect an external antenna to the MR6500 do I need to use both TS9 connectors?
1 ReplyReplies sorted by OldestJohnPengNETGEAR ExpertMar 09, 2023Yes. You should connect both TS-9 connectors. Thanks
