monsoon_moon
Jun 04, 2023Aspirant
Nighthawk M6 Pro Extremely Sluggish
Hi all - I am in the exact same situation as the OP on the below thread. https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/Nighthawk-6-PRO-MR6500/m-p/2303494 The OP claimed the soluti...
monsoon_moon
Jun 07, 2023Aspirant
Bumping this thread... not sure how to raise attention otherwise.
dmcshaw61
Jun 11, 2023Tutor
I also have the same issues.
I have sent my json file to John Peng, and I am still waiting for a response!
- JT240ZJul 22, 2023Luminary
Same problem here as well. Same firmware version. Can't seem to get an update since the device says I'm up to date.
- JohnPengJul 22, 2023NETGEAR Expert
AT&T is rolling out the update of FW 12.01.16.01 gradually. It should come to your devices in the next couple of weeks.
Thanks
Seems like the fixes are always delayed by AT&T. I don't envy your position with these problems. Netgear has created some of their own problems, but they're always complicated by AT&T's distribution system.
Thanks for any help you've provided.
