monsoon_moon
Jun 04, 2023Aspirant
Nighthawk M6 Pro Extremely Sluggish
Hi all - I am in the exact same situation as the OP on the below thread. https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/Nighthawk-6-PRO-MR6500/m-p/2303494 The OP claimed the soluti...
bombsquadrob
Oct 03, 2023Initiate
I have the same issue as well at my sisters house. If you hook up the device directly to a laptop, the speeds are about 220mbps download. But if you connect it to a network switch the performance drops to about 20mbps.
She does live in a remote area and the only cell tower is an AT&T tower so this is her only option.
Suggestions? I thought about tethering it to the computer next to it and doing an internet sharing config to test, but welcome to other suggestions.
saminmel
Feb 18, 2024Aspirant
I encounter the same issue.
Here's my solution.
1. Remove the back cover, and battery,
2. Connect it to usb power, and switch it on,
3. Put a cooler fan under it
