JVB2112
Jan 15, 2025Aspirant
Nighthawk M6 Pro firmware NTGX65_12.01.54.00 Release Notes?
My M6 Pro just told me that a firmware update was available and I applied it. However, after applying it, it seems to have the same version number as the one that was released in April 2024. Did...
rcpax
Jan 16, 2025Luminary
JVB2112 wrote:My M6 Pro just told me that a firmware update was available and I applied it. However, after applying it, it seems to have the same version number as the one that was released in April 2024.
Did I just apply something new and they just forgot to change the build number?
the GUI version and the PRI version have been bumped up. PRI from 5.09 to 5.12, GUI x.107 to x.109. It is overall the same FW with some updates, maybe that's why the main FW number did not change. Did a quick browse through the GUI, no change that I can see. I do not have the specifics on the changelogs though.
