aleibel
May 26, 2024Follower
Nighthawk M6 Pro, Model MR6500 connect or not when not using for extended period of time
I just purchased the M6 Pro for our RV and it worked fine. We will not be traveling for a couple of months and will not be using it during that period of time. Is better to leave it connected to po...
May 26, 2024Guru - Experienced User
If you're not planning on using it at all, power it off and pull the battery.
