RickC66
May 24, 2023Follower
Nighthawk M6 Pro MR6400 Service
I recently purchased the hotspot from Dish Project Genesis and had no issues ordering or setting it up. I was able to use it for about 3 weeks and everything was golden. I did not travel so it sat on...
stevediaz
Aug 20, 2023Aspirant
Hello
It seems like the recent change in behavior might be related to a network or authentication issue with the hotspot. Since you've already contacted Project Genesis for support and they are working on it, I recommend giving them a bit more time to resolve the issue. In the meantime, you could also try connecting to the hotspot using a different device to see if the problem persists across multiple devices. If the problem persists, keep communicating with their support team for updates and solutions.
