ALM_
Dec 30, 2022Aspirant
Nighthawk M6 Pro MR6400 won't connect to native Dish network
Nighthawk M6 Pro MR6400 Firmware - NTGx65_10.01.41.02 For the first five days of use, the hotspot connected to the native Dish/Genesis network. It then switched to roaming and has not been able to ...
- Jan 28, 2023
ALM_ wrote:
aiotechnv Thanks for the reply. Masking the network isn't an issue. I included that info just to try to fully describe the situation.
Not being able to connect to the native Dish network when available is the problem.
Shout out to JohnPeng for the help in confirming it is/was not a hardware problem and for reaching out to Dish on my behalf.
Oddly, a few days ago, my other modem (that was connected natively to Dish for months) lost it's data connection when connected to Dish but insists on still connecting to the native network. I have to force it onto other networks.
I can confirm that the issue is not device related. Since the issue follows with SIM card, we had provided the related information to Dish and they are checking on their network side. I can contact Dish to see whether we can receive some updates on this issue.
Thanks
JohnPeng
Jan 06, 2023NETGEAR Expert
For the first five days of use, the hotspot connected to the native Dish/Genesis network. It then switched to roaming and has not been able to connect to the native Dish network in over three weeks. All trouble shooting (including a replacement sim) has failed.
Any help/ideas/suggestions would be much appreciated.
Note: I have another identical set up that does connect natively to Dish.
For Dish MR6400, we are going to release a maintenance release later this month. The issue should be resolved in the release.
The roaming to AT&T network is treated as Home by Dish, so you don't need to worry about roaming display.
In the coming MR release. you will not see roaming when the device connects to AT&T network.
Thanks
John
- ALM_Jan 07, 2023Aspirant
Hello John & thank you for the reply.
When roaming I appear to be jumping back and forth between AT&T and T-Mobile and always have a 4G connection.
The "Current Radio Band" will frequently switch and the quality of the connection varies wildly.
The display always says that I am connected to Dish 5G - but the diagnostics & data usage say I am roaming.
My other hotspot maintains an almost constant and very stable 5G connection.
If I swap the sim cards between the two hotspots I have, the issue follows the sim card (i.e. - the hotspot that was connecting to the native 5G Dish network will go into roaming and vice versa).
This is something that a firmware update may resolve or is it likely something is wrong with the way the account is setup?
I have been working with the Project Genesis support to try to determine the cause.
Thanks again,
Aaron
- JohnPengJan 07, 2023NETGEAR Expert
Thanks for the detailed information. Since the issue follows with SIM card, it points to the SIM card setup issue. Since Dish is using AT&T and T-Mobile networks as roaming partners to extends its network coverage, the SIM cards need to be configured with proper info to support this. Better to request a new SIM card from Dish and see whether the issue goes away.
Thanks
- ALM_Jan 08, 2023Aspirant
Yes - I have replaced the SIM and the problem persists.
The fact that there were no issues for the first five days has me confused as to what the problem may be.
I'll keep working with Dish to try to resolve this.
Thank you John,
Aaron
