Fabrice75
Sep 02, 2023Aspirant
Nighthawk M6 Pro (MR6450) & Antenne
Bonjour,
Est il possible de déporter l’antenne de 30m environ (pour l’installer en haut du mat d’un bateau) ?
Merci
While there are some cunning linguists here, you might do better to seek help in your language community.
Try here:
Français - NETGEAR Communities
- Fabrice75Aspirant
Hi
I'm gonna doit in english then 😀
Is it possible to connect the antenna approximately 30m from the Nighthawk M6 Pro (to install it at the top of the mast of a boat)?
Thanks
