pyun
May 22, 2023Tutor
Nighthawk M6 Pro (MR6450) keeps restarting itself during high download speed
Just like the topic suggest. My MR6450 keeps restarting itself during high download speed. The thing is that it does it every time I start a download on Steam. When it gets around 50-60mb/s that's wh...
May 23, 2023Guru - Experienced User
Do you have the battery in it?
Is it running of AC power? Or battery?
Are you connected to it over wireless or over wired connection?
A small laptop fan might not be a bad idea if its getting that hot.
