pyun
May 22, 2023Tutor
Nighthawk M6 Pro (MR6450) keeps restarting itself during high download speed
Just like the topic suggest. My MR6450 keeps restarting itself during high download speed. The thing is that it does it every time I start a download on Steam. When it gets around 50-60mb/s that's wh...
pyun
May 23, 2023Tutor
No battery. It's AC-Powered.
It's connected over wired connection. Although, there are 2 routers in between the Nighthawk M6 Pro.
My PC > Access point router > Router > Nighthawk M6 Pro.
The reason for all of that is because I am in a cabin outside my house. The Nighthawk M6 Pro is inside the house.
At first it only happened sometimes, but now it happens everytime I download something. Very annoying.
May 23, 2023Guru - Experienced User
Just to test it, does it happen if the battery is in it?
I've seen some power supplies that can't put out their full power and under load, cause issues.
So might be worth checking to see if maybe when its under load, if its overloading the power supply and causing the reboot.
- pyunMay 23, 2023Tutor
I will try just that. I'm just afraid that the download speed will be so much lower. But I guess a working router is better than a router that restart itself all the time.
- plemansMay 23, 2023Guru - Experienced User
Not saying you have to stick like that. Just for testing to figure out where the issue is stemming from.
- pyunMay 26, 2023Tutor
I thought I'd give an update on my situation.
I switched to battery and ran with it a few days and so far there has been no reboots, but... The connection can be unstable at some point. Then there's the issue of the speed. Usually I'm around 500-700 mbit but now I'm at 80 mbit.
So I tested a speedcheck on my mobile phone just to see if it was my location. My phone reached 800 mbit so it clearly is not my location.
I have rebooted the Nighthawk and my routers many times only to see that none of it worked.
My conclusion is that there is something wrong with my Nighthawk M6 Pro.
It is just so frustrating to spend almost 1000 euro/dollars on something that does not work the way it is supposed to.
I will just contact support and see if I can send it for a fix.
