Racingmacat
May 12, 2023Aspirant
Nighthawk M6 Pro (MR6450)
I recently purchased this, dare I say, rather expensive product & must say that thus far I'm having trouble finding the optimum settings to achieve reasonable wifi coverage either on battery power or...
- May 13, 2023
I have the MR6110. their range isn't the greatest for their wifi as their a hotspot.
Connecting it to your eero is a great option for better coverage.
You'd want the M6 put in passthrough mode when you connect it to the eero.
May 13, 2023Guru - Experienced User
- RacingmacatMay 13, 2023Aspirant
Thank you very much Plemans, you comments are much much appreciated.
