awachterberg
Jan 18, 2024Aspirant
Nighthawk M6 pro Mr650 charger not working
Charger stopped working, contacted support and told me out of warranty. It appears this is a common fault with this charger yet Netgear will not back this up with a replacement. Now need to purchase ...
michaelkenward
Jan 18, 2024Guru - Experienced User
awachterberg wrote:
Charger stopped working, contacted support and told me out of warranty. It appears this is a common fault with this charger yet Netgear will not back this up with a replacement. Now need to purchase 3rd party charger as I cannot locate genuine charger
Are you asking for help in finding a replacement?
Netgear generally seems to be reluctant to sell replacement chargers and adapters.
Any generic device should work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
In your case, have you ruled out the battery? These generally have a shorter life the chargers.
For better advice, trying asking in the section given over to things like the MR650:
awachterberg
Hi, thank you for the response. I have ordered another charger which i hope will be compatable. My main of concern is tha5 it appears that Netgear knows this problem yet not offer replacement.
Albert
- plemansJan 18, 2024Guru - Experienced User
Albert
Every company knows that power supplies will fail. Its just most companies will sell replacements if they're not generic.
Your charger for the M6 uses a standard so you can pickup one from anywhere. You might have even had one sitting around from a phone.
