kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
kbee
While I appreciate the tips, I wouldn't have posted a question this specific if I could find it in the the generic manuals for the device. This provided no solution to me.
Thank you for moving the thread to a more relevant forum - appreciate it!
Any tips/advice from the rest of the community?
schumaku
Jul 23, 2022Guru - Experienced User
The only two MR6500 versions I'm aware come with dedicated band plans for ATT and Telstra Australia. there are in no aspect universal world-wide models. Matching tech and band would be pure luck on a global use base:
Technology / Bands
• LTE CAT 20
• 5G Sub-6: n2, n5, n12, n14, n29, n30, n66, n77
• 5G mmWave: n260
• LTE: B1, B2, B3, B4, B5, B7, B12, B14, B29, B30, B46, B48, B66
• Carrier Aggregation
- Up to 5x Carrier Aggregation on LTE (CA)
- Up to 9x Carrier Aggregation on 5GNR (NRDC)
- Up to 12x Carrier Aggregation on L TE+5GNR (ENDC)
- Up to 2X Up-link Carrier Aggregation on LTE and 5NGR
• Increase network performance and reduce interference with 802.11axe (WiFi 6E), 2x2 MIMO and 2.4/5/6GHz dual band***
• Latest 5G technology:
- 5GNR Sub-6 and mmWave
- 5GNR Sub 6GHz (N)SA
• Secure mobile Internet to deliver incredible download speeds; 5G-enabled with LTE fallback
• Supports LTE CAT 20, LTE Advanced Pro, 4x4 MIMO, 256-QAM
Technology / Bands
• LTE CAT 20
• 5G Sub-6: n5/n7/n28/n78
• 5G mmWave: n258
• LTE: B1,B3,B7,B28
• 3G: B1,B5
Carrier Aggregation
- DewdropNov 02, 2022Aspirant
That would explain why it is not able to connect to mmWave bands, but shouldn't it still function with the Sub-6 bands, or at least fall back to LTE? I like the specs, but the bands available seem too limited to make it worth it for someone traveling a lot.
- JohnPengNov 03, 2022NETGEAR Expert
AT&T device doesn't have the band support for EU countries. That might be the reason why the device can't connect to Telia network.
Thanks
John
