kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
ErwanVi
Nov 04, 2022Aspirant
Hello kbee
I just did a similar purchase from eBay: NETGEAR Nighthawk M6 Pro MR6500 AT&T +GSM Unlocked from the seller qualitycellz. 5G WiFi 6E Mobile Router (MR6500) . I am taking a big risk (~1000€ with import taxes and shipping to France) but I wanted the best mobile router, for professional and domestic purposes (very bad cable and LTE internet in my area, but great 5G signal)
Since it's supposed to be "GSM unlocked" and the router covers all the bands of 5G antennas near my working environment, it should be fine. I'm getting worried after seeing your post, though.
Did you manage to make it work? And if you did, what method did you use?
- W1lliamNov 16, 2022Virtuoso
Best 5G mobile router for Europe still MR5200-100EUS at the moment, not seeing sign of M6/M6 Pro for EU yet
- RTWbyBIKE_comFeb 26, 2023Aspirant
[del double post]
Hello did you receive it and make it work? I ordered the same thing (NETGEAR Nighthawk M6 Pro MR6500 AT&T +GSM Unlocked) and now I am wondering if it will work in Europe???
Thank you in advance for your answer....- QountdownApr 27, 2023Aspirant
Hi,
Did this ever work for you?
- LondonFranceSep 27, 2023Aspirant
Hello community,
I am thinking of buying a Nighthawk M6 off eBay while I am in the US for use later in France. I know that the Nighthawk is marketed and sold in France but will one bought in the US work anywhere else in the world? Just wondered if anyone has done the same thing and is able to advise. Thank you in advance.
Norman,
