kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
ErwanVi
Nov 04, 2022Aspirant
Hello kbee
I just did a similar purchase from eBay: NETGEAR Nighthawk M6 Pro MR6500 AT&T +GSM Unlocked from the seller qualitycellz. 5G WiFi 6E Mobile Router (MR6500) . I am taking a big risk (~1000€ with import taxes and shipping to France) but I wanted the best mobile router, for professional and domestic purposes (very bad cable and LTE internet in my area, but great 5G signal)
Since it's supposed to be "GSM unlocked" and the router covers all the bands of 5G antennas near my working environment, it should be fine. I'm getting worried after seeing your post, though.
Did you manage to make it work? And if you did, what method did you use?
W1lliam
Nov 16, 2022Virtuoso
Best 5G mobile router for Europe still MR5200-100EUS at the moment, not seeing sign of M6/M6 Pro for EU yet
- JohnPengNov 18, 2022NETGEAR Expert
EU Version MR6450 will be launch soon.
Thanks
- Pras1011Jan 10, 2023Aspirant
Will the Australian version be ok for use in the UK?
- W1lliamJan 10, 2023Virtuoso
Australia version of M5/M6 supported bands listed below
MR5100-1TLAUS
LTE: B1/B3/B7/B8/B28
NR5G: n5/n7/n78
MR6110-1TLAUS
LTE: B1/B3/B7/B28
NR5G: n5/n7/n28/n78
MR6500-1TLAUS
LTE:B1/B3/B7/B8/B28
NR5G: n5/n7/n28/n78/n258
M5/M6 EU version are
MR5200-100EUS
LTE:B1/B3/B5/B7/B8/B20/B28/B38/B40/B41/B42
NR5G: n1/n3/n5/n7/n8/n20/n28/n38/n40/n77/n78
MR6450-100EUS
LTE:B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B20/B28/B38/B40/B41/B42/B66
NR5G:n1/n2/n3/n5/n7/n8/n20/n28/n38/n40/n41/n71/n77/n78
MR5200-100EUS seems fits well for UK, so if you are planning to have the device worked in European, suggest not to take Australia but EU version instead
