kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
JohnPeng
Nov 18, 2022NETGEAR Expert
W1lliam wrote:
Best 5G mobile router for Europe still MR5200-100EUS at the moment, not seeing sign of M6/M6 Pro for EU yet
EU Version MR6450 will be launch soon.
Thanks
Pras1011
Jan 10, 2023Aspirant
Will the Australian version be ok for use in the UK?
- W1lliamJan 10, 2023Virtuoso
Australia version of M5/M6 supported bands listed below
MR5100-1TLAUS
LTE: B1/B3/B7/B8/B28
NR5G: n5/n7/n78
MR6110-1TLAUS
LTE: B1/B3/B7/B28
NR5G: n5/n7/n28/n78
MR6500-1TLAUS
LTE:B1/B3/B7/B8/B28
NR5G: n5/n7/n28/n78/n258
M5/M6 EU version are
MR5200-100EUS
LTE:B1/B3/B5/B7/B8/B20/B28/B38/B40/B41/B42
NR5G: n1/n3/n5/n7/n8/n20/n28/n38/n40/n77/n78
MR6450-100EUS
LTE:B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B20/B28/B38/B40/B41/B42/B66
NR5G:n1/n2/n3/n5/n7/n8/n20/n28/n38/n40/n41/n71/n77/n78
MR5200-100EUS seems fits well for UK, so if you are planning to have the device worked in European, suggest not to take Australia but EU version instead
