kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
Pras1011
Jan 10, 2023Aspirant
Will the Australian version be ok for use in the UK?
W1lliam
Jan 10, 2023Virtuoso
Australia version of M5/M6 supported bands listed below
MR5100-1TLAUS
LTE: B1/B3/B7/B8/B28
NR5G: n5/n7/n78
MR6110-1TLAUS
LTE: B1/B3/B7/B28
NR5G: n5/n7/n28/n78
MR6500-1TLAUS
LTE:B1/B3/B7/B8/B28
NR5G: n5/n7/n28/n78/n258
M5/M6 EU version are
MR5200-100EUS
LTE:B1/B3/B5/B7/B8/B20/B28/B38/B40/B41/B42
NR5G: n1/n3/n5/n7/n8/n20/n28/n38/n40/n77/n78
MR6450-100EUS
LTE:B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B20/B28/B38/B40/B41/B42/B66
NR5G:n1/n2/n3/n5/n7/n8/n20/n28/n38/n40/n41/n71/n77/n78
MR5200-100EUS seems fits well for UK, so if you are planning to have the device worked in European, suggest not to take Australia but EU version instead
