kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
ErwanVi
Nov 04, 2022Aspirant
Hello kbee
I just did a similar purchase from eBay: NETGEAR Nighthawk M6 Pro MR6500 AT&T +GSM Unlocked from the seller qualitycellz. 5G WiFi 6E Mobile Router (MR6500) . I am taking a big risk (~1000€ with import taxes and shipping to France) but I wanted the best mobile router, for professional and domestic purposes (very bad cable and LTE internet in my area, but great 5G signal)
Since it's supposed to be "GSM unlocked" and the router covers all the bands of 5G antennas near my working environment, it should be fine. I'm getting worried after seeing your post, though.
Did you manage to make it work? And if you did, what method did you use?
RTWbyBIKE_com
Feb 26, 2023Aspirant
[del double post]
