kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
RTWbyBIKE_com
Feb 26, 2023Aspirant
Hello did you receive it and make it work? I ordered the same thing (NETGEAR Nighthawk M6 Pro MR6500 AT&T +GSM Unlocked) and now I am wondering if it will work in Europe???
Thank you in advance for your answer....
Qountdown
Apr 27, 2023Aspirant
Hi,
Did this ever work for you?
