kbee
Jul 23, 2022Aspirant
Nighthawk M6 Pro MR6500 - Using Internationally (Telia/Chilimobil) Won't Connect to Internet
I have a new MR6500 purchased domestically in the States, factory unlocked per my eBay seller. I travel quite a bit abroad and have a norwegian Data Sim with Chilimobil (using Telia's networks) and w...
Yeking
Aug 15, 2023Aspirant
Have you try to change APN? Make sure you find the apn of a particular network you are connecting to and go to settings on the router to change apn so it can give a room for the said network
