motohead761
May 02, 2023Tutor
Nighthawk M6 Pro MR6500 (AT&T)
Greetings, I'm having the same dropping devices then not reconnecting that has been well documented . Constantly having to restart the modem thru out the day to stay connected. I did copy the jso...
May 02, 2023Guru - Experienced User
How are you using it?
Using both 2.4ghz and 5ghz?
Are you using it with constant power? And if so, is the battery removed?
How many devices are connected?
Are they direct connected or do you have a router connected and then devices to that?
- motohead761May 02, 2023Tutor
I,m using both 2.4 ghz and 5 ghz as I have security cameras that require 2.4
Constant power with battery removed to supply the 2.4 ghz via ethernet to a router setup as an access point.
16 devices max with 11 direct connected and 5 thru the access point router
- plemansMay 02, 2023Guru - Experienced User
What router is setup in access point mode?
Have you tried putting the M6 in passthrough mode and the other router in router mode?
- motohead761May 03, 2023Tutor
My understanding is with the M6 you have to remove the battery to get it to work in pass thru mode.
I did that and via cat5 cable to another (farm) building I,m supplying a ASUS RT-N66U router setup as an access point.
I,ve got another ASUS RT-N66U in my home along with the M6 but its just boosting my wifi signal wirelessly.
The system works most of the time just over the course of the day , I have devices that show there connected but they are not transferring data. Only way to get them to reconnect is retsart the M6. This seems to be a fairly common problem with the M6 it goes into a search and just stays there and doesn't connect . Its been discussed on other threads in this community and my local AT&T store is getting multiple Identical complaints.
