motohead761
May 02, 2023Tutor
Nighthawk M6 Pro MR6500 (AT&T)
Greetings, I'm having the same dropping devices then not reconnecting that has been well documented . Constantly having to restart the modem thru out the day to stay connected. I did copy the jso...
stevediaz
Aug 20, 2023Aspirant
Hello
Thank you for reaching out and sharing your experience. It's unfortunate that you're encountering the same issues with dropped connections and the need for frequent modem restarts. Providing the JSON file to jopeng@netgear.com was a proactive step, and I hope that they will be able to analyze it to find a solution for your connectivity problems.
