VocalMinority
Jul 28, 2024Follower
Nighthawk M6 Pro MR6500 can’t add of modify Offloading Wi-Fi Networks
Nighthawk M6 Pro MR6500 can’t add of modify Offloading Wi-Fi Networks. Has anyone else experienced this problem? This bug appears to have been introduced in the last 7 months, perhaps in a recen...
michaelkenward
Jul 28, 2024Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
