MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
JohnPeng
Jun 12, 2023NETGEAR Expert
Can you capture a model.json file and send to me at jopeng@netgear.com. please mention your community id in the email.
Please also detail your use case and device setup, etc.
Thanks
John
Thanks
John
gladu2
Jun 12, 2023Aspirant
Hello John, I emailed the information you requested. Hope you can help.
