MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
JohnPeng
Jun 13, 2023NETGEAR Expert
Telstra is going to approve a new release soon. Please email me your device IMEI to jopeng@netgear.com and mention your community ID. I can set your device up to preview the coming maintenance release. It includes many feature enhancements and resolves data stability issues as you saw in the current release.
Regards
sbrady4
Jun 20, 2023Tutor
I'm having similar problems with an AT&T M6 (MR6110) less than 1 week old. I'm using it without battery and ethernet only (wifi off) to feed my router. After various lengths of time (1 hour, 8 hours, 2hours) it drops out - the internet connection is dropped. Unplugging it and restarting it usually fixes it.
