MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
DistillMill
Jun 20, 2023Aspirant
I'm having the same issue with mine. I've sent an email with my model.json data
dmcshaw61
Jun 23, 2023Tutor
I am also having these problems. I am using with no battery and in performance mode. I am getting lower speeds and pings the longer it is on. It randomly disconnects without losing signal. Resetting seam to help, but doesn't last long. Current version is NTGX65_12.01.16.00. Any help would be appreciated
- dmcshaw61Jun 23, 2023TutorModel number mr6110 from AT&T
- dmcshaw61Jun 23, 2023TutorMr Peng
I have sent you my json file
Thanks for your assistance
- sbrady4Jun 23, 2023Tutor
My firmware was NTGX65_10.01.47.00, so at least you have a more updated version.
- dmcshaw61Jun 23, 2023TutorYes, but it got worse with the new update!
