MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
gladu2
Jun 23, 2023Aspirant
sbrady4 wrote- I'm still in the AT&T 14 day return/replace, so I'm getting it swapped out to see if that helps any. Thanks for trying with AT&T. (it also has a 1 year warranty).
Could you please report back on this thread whether swapping it out fixed your problem? I returned my mr6150 that was doing the same thing.
sbrady4
Jun 23, 2023Tutor
I’m going to try the replacement first. Mine seemed like it was going in some kind of software loop and getting bogged down and overheating. It would get where you couldn’t even use the touch screen. I’ll let you know if it works better but it will be a while before I get it and get back here where I use it.
