MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
JohnPeng
Apr 11, 2024NETGEAR Expert
jdrch Please capture a model.json file and email me at jopeng@netgear.com.
For Verizon disconnection issue, most likely it is related to Verizon data plans. If you use the Verizon SIM card from a phone, you may see the issue. I can set your device to update to the next MR release candidate. Then we can work from there. I helped a few Verizon customers to resolve the issue. I will provide the details by email.
You can also check the following community case.
Solved: Netgear M6 Pro MR6550 - Verizon Connection Issues - NETGEAR Communities
Thanks
John
jdrch
Apr 11, 2024Apprentice
Emailed as advised.
