MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
jdrch
Apr 13, 2024Apprentice
> Netgear does nowhere specify 9V/1.8A in any MR6550 documentation
It's the output voltage listed on the AC adapter that ships with the device. However, you're correct that the adapter is a QuickCharge one. I missed that logo when I was looking at it yesterday. My apologies.
Anyway, I did some more testing overnight and today at home with different cables and chargers and have been unable to replicate yesterday's signal drops. For now, it seems the solution is to change the plan as JohnPeng suggested and then wait a few hours for the change to propagate. I've even rebooted it since and it connected to the internet immediately upon picking up signal.
I also picked up an Inseego MiFi 5G X PRO today direct from Verizon for comparison. So far the Inseego is much easier to setup and doesn't need a reboot for stuff like changing the Ethernet port status, but the MR6550 has 3 dB better SINR at the same location (~2x better) and of course has the antenna capability.
I'll test both at the problematic location from earlier in the thread next week (hopefully Monday).
jdrch
Apr 15, 2024Apprentice
The MR6550 lasted an entire weekend at home in my basement without any connection drops. Testing some more in the remote location this week. So far, the MR6550 is able to maintain an internet connection for longer, but still drops eventually. The Inseego MiFi X Pro 5G's connection is both faster and has fewer drops. I'd run a speedtest on both, but I had difficulty loading an entire page on the MR6550.
I'm actually posting this message from the Inseego connection.
I ordered a Proxicast antenna for the MR6550 over the weekend; it should be delivered tomorrow. I'll see how it performs later this week.
- jdrchApr 17, 2024Apprentice
Left the MR6550 at home today as the antenna hadn't been delivered yet and the Inseego MiFi X PRO works better in the remote location.The Inseego was trouble-free today.
Firmware update to NTGX65_12.01.54.00 within the past hour. Gonna factory reset as typically advised - ironic, since the firmware update wipes some of the UI customizations anyway - and see how it goes. Might not be able to visit remote location again until next Monday, so further testing in that environment may be delayed.
Wound up going to the remote location today after all and it was bad news for the MR6550. Network Map was fine when I got there but then dropped to ❌ as before. Even a reboot failed to fix the problem. About to try the Proxicast antenna, though I'm not sure how that might help the fact that the MR6550 can't connect to the internet in the same conditions and same location as the Inseego MiFi X PRO. The antenna is already here though, so might as well try.
Update: Antenna test is a bust. Can't get the TS9 connectors on the antenna to mate with the ones on the MR6550.
So yeah I'm out of ideas at this point. Gonna set up an RMA for MR6550 shortly.
