MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
blackpen
May 21, 2024Aspirant
Got a brand new nighthawk m6 pro and unlimited hot spot data plan from Verizon today.
Worked for a bit and then dropped connection. Factory reset worked for a bit then dropped connections again.
Seems like this product is unreliable.
