MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
bcook17
Jul 08, 2024Aspirant
Hi @JohnPeng
The have a MR6500 with AT&T and have the same problems with the ethernet port dropping the connection when set to 1GB or above. If I set to 100 MB it maintains a more stable connection but looking to use the 1GB or 2.5 GB ethernet port for my network here at my house.
I sent you an email with the model.json file. I hope you can help me solve my issue.
Thanks,
Brandon
JBish
Sep 02, 2024Aspirant
Guess this could be a question for all... Firmware revisions?... I know with earlier versions of firmware it was a mess with many of these issues being seen...
