waterwheelfarm
Apr 05, 2024Aspirant
Nighthawk M6 Pro MR6500 hot spot OEM power adapter
I purchased a refurbed unit through amazon and it did not come with a netgear power adapter & cord. I want to run this unit without the battery, but when I removed it, received the message: Use t...
- Apr 06, 2024
The one you found should work at 5V/3A/20W. The voltage is critical, but the amperage and wattage can be anything above what you stated. A 4-amp 30 or 40W adapter would be better. I don't have mine in front of me but when I get home, I'll see if it has a specific rating.
JT240Z
Apr 05, 2024Luminary
Unfortunately Netgear has chosen to not sell the power adapter by itself. No way to purchase the "OEM Netgear" power adapter.
waterwheelfarm
Apr 06, 2024Aspirant
Well that's a shame. I wish they would at least confirm what I should get.
Does anyone know the correct volts/amps/watts I should use with this to run without the battery?
